[Solved] Prusa Link not Working
MaVeRa
(@mavera)
Hello! Prusa link is not charging for 5-6 days (The connection has timed out). What is happening? Do you guys have this problem? I am using mozilla browser.
This topic was modified 2 years ago by MaVeRa
Posted : 26/12/2023 3:40 pm
MaVeRa
(@mavera)
RE: Prusa Link not Working
Today also the page in the browser does not load. Similar problems??
Posted : 27/12/2023 2:37 pm
MaVeRa
(@mavera)
I am waiting for a response from the "Customer Support" or "Moderators".
This post was modified 2 years ago by MaVeRa
Posted : 28/12/2023 11:26 am
JP Guitars
(@jp-guitars)
Works fine for me - firmware version 5.1.2.
I am also getting a ping response from it
Posted : 28/12/2023 12:12 pm
MaVeRa
(@mavera)
I haven't upgraded to the new firmware yet. I'm thinking of waiting for the next one because everything else is working fine.
Posted : 28/12/2023 5:46 pm
mixer3d
(@mixer3d)
Try to replace ESP01s module: https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/wifi-network-performance-dependent-on-the-esp01s-module-used/
Posted : 28/12/2023 9:11 pm
MaVeRa
(@mavera)
I fixed the problem! For some reason, PrusaLink's IP address had changed.
Posted : 29/12/2023 2:03 pm
mixer3d
(@mixer3d)
ah, good, so could be that in that case probably some other device in your local network took over the same IP address, you can then extend the lease time in your router, so IP  DHCP assigned addresses assigned will stay for longer for particular MAC addresses...
Posted : 29/12/2023 3:15 pm
JP Guitars
(@jp-guitars)
Depending on the router you may be able to permanently allocate an IP address or even give it a name.
Posted : 29/12/2023 3:20 pm
SolitaireMakes
(@solitairemakes)
That's mostly likely since you are using DHCP where the router is assigning a new IP address when the current lease expires. To mitigate this, you can force assign an IP address to your printer so that it never changes. Most of the routers have this option (called different things depending on the make of the router, but what you are looking for is "static IP address").
Posted : 29/12/2023 8:23 pm
