Print Fan/Cooling Fan high frequency noise
Sephzer
(@sephzer)
Anyone else getting a high pitch frequency noise from either fan? I just finished building my MK4 and my god... the frequency is unbearable. I'm someone that has to return things for the slightest noise as I'm really prone to it, my ears are super sensitive. Not sure I can have this running in the same room at this rate. It's worse when I'm not printing or before the fan really starts to get going, but it's so bad I've had to put earplugs in.
I am guessing this is something to do with it being a PWM fan and it probably not getting enough voltage. Anyone had similar issues? Cheers.
Opublikowany : 04/09/2023 12:58 pm
