Plated copper heater block
weak
 weak
(@weak)
When?
What good is the V6 nozzle adapter if you can't even print CF?
Publié : 09/04/2023 2:19 pm
Markus1978
(@markus1978)
RE: Plated copper heater block
Why not? Adapter and hardened nozzle. done.
Posted by: @weak
When?
Publié : 07/05/2023 10:12 am
weak
 weak
(@weak)
Because TC nozzles tend to come loose with the stock heater block on the MK3. I guess the same applies here.
Publié : 08/05/2023 6:24 am
Snow
 Snow
(@snow-2)
Posted by: @weak
When?
So a V6 nozzle adapter is useless unless you can print CF?
Publié : 08/05/2023 1:59 pm
Cynan
(@cynan)
Can you not attach a third party one?
Publié : 09/05/2023 10:09 am
I just experienced a major blob with my XL using the nozzle adaptor and a TC nozzle. I've swapped nozzles on my four Mk3S and Minis, which all have Dragon hotends and TC nozzles, literally hundreds of time, never had an issue, so I'm pretty sure I did everything right. Yet, I couldn't help but wonder if I might have made a mistake after all. But the Dragon has a copper heater block, so, yeah, maybe the fact that it's TC on brass was in fact the root cause. But I'm not going to test it again anytime soon, without a ready supply of hotend components, just in case something goes sideways.
Ce message a été modifié il y a 3 years par
Publié : 11/05/2023 10:59 am
