Nozzle “clogging” mid print
I’ve been having trouble with prints failing midway through for some reason. I’ve been using the ELEGOO Black and White PLA using the generic PLA settings in Prusaslicer. Based on the filament unload, it doesn’t look like heat creep and it seems like the filament is getting stuck. I have other PRUSA MK4s and it doesn’t seem to be an issue with the same settings and filament. I’ve tried changing the extruder and it seemed to work up to a bit. No cracking noises; pushing the filament through seems to help purge it out, but the extruder can’t seem to do it by itself.
This topic was modified před 1 year by genbu
Napsal : 15/10/2024 8:43 pm
