Noise on X-Asix
Hi all,
My mk4 makes a weird noise when moving slow on X-Axis. Please check out this " MK4 noise on X-Axis " video, the noise can be heard when the movement is only on the X axis. This happened to me after I did a long maintenance, where I disassembled some parts of the printer to clean and lubricate.
Do you know what is the problem and how I can fix it?
Thank you in advance
Napsal : 04/12/2025 7:32 pm
1 lidem se líbí
RE: Noise on X-Asix
I've the same issue, though I must say your printer sounds whisper quiet otherwise.
Napsal : 07/12/2025 12:44 am
Topic starter
answered:
RE: Noise on X-Asix
I recorded a new video (IMG_5727) that better shows the noise.
@Ruben: can you check out the new video, I think this noise is not normal.
Napsal : 12/12/2025 8:58 am
