Nextruder block keeps coming loose
Al Bear
(@al-bear)
Membre
I think this was a well-known problem but I can't see any recent posts..   I tighten the nextruder block with the wheels on the side but halfway  through a print it then comes loose again .. and  results in a "jammed filament" message.. but it actually isnt jammed , as it works fine once I re-tighten ..  this was a new machine and this problem has been intermittent since I got it... should I re-screw the whole nozzle in ?  As the wheels are now very tight .. bit after a  2-3mins , print I can waggle the whole block quite easily ..
Hoping that this issue was solved by many some time ago ...  thanks
Publié : 11/05/2025 5:34 pm
Your fix is probably thread locking compound (liquid/paste) but first take this to Prusa Support via chat.
Publié : 11/05/2025 6:45 pm
Al Bear
(@al-bear)
Membre
RE: Nextruder block keeps coming loose
appreciated 🙂
Publié : 11/05/2025 7:17 pm
Brian
(@brian-12)
Posted by: @al-bear
Can you be more specific with some pictures?  I'm not familiar with any wheels on the Nextruder.
Publié : 12/05/2025 1:21 am
