Need to adjust vertical positioning of text on display
fabnavigator
(@fabnavigator)
The text on the display on my printer needs to be shifted up about 1mm. The characters on the bottom status line almost have their bottoms cut off, and I have plenty of extra space above the top row of text. Has anyone else noticed this? I might have to contact support if no one knows how to adjust this.
Opublikowany : 04/02/2024 10:25 pm
First check the display has not been knocked out of its proper position within the case.
Opublikowany : 04/02/2024 11:20 pm
fabnavigator
(@fabnavigator)
RE: Need to adjust vertical positioning of text on display
Nope. The display is firmly glued onto a piece of foam, that is firmly glued to the board. And the board fits snugly into the front cover.
Opublikowany : 06/02/2024 1:31 am
OK, contact support.
Opublikowany : 06/02/2024 6:50 am
fabnavigator
(@fabnavigator)
Mystery solved. I contacted support and they said "there might be some displays with a slight offset but so far there was no issue reported on this. I'm not sure how long it might take for our development to include this in their list but I will definitely make sure they will take a look at it". They went on to say "the lcd can be usually disassembled without an issue , it's not sticking too much".
I decided to give it a shot. I carefully (with a thin plastic tool) pried the LCD including the black foam off of the PCB. It wasn't too bad to get it off. I cleaned off a little of the foam that was left on the PCB. I attached a picture of the PCB without the LCD. I noticed that there is a white outline indicating the placement of the LCD. Apparently, whoever did the assembly, didn't place it just right. I was able to place the LCD better and I'm happy with the result. I didn't add any additional glue, so I can remove it and reposition it easily now. But it still sticks well enough. As I said initially, it was only off my about 1mm.
Opublikowany : 06/02/2024 6:58 pm
