(multycolor) excess material extruded after every filament change
Matej
(@matej-3)
Utenti
Hello,
i am trying to do some multicolor print but it always fail becouse of excess material extrusion, after every color change, blocks printing head.
i have mk4 with current firmware, using prusaslicer. I use octoprint but tryed it directly from usb too.
i did only few changes to default profile - extruders: 7, enable single extruder multi material, added line to "tool change gcode" (M600).
for purpose of this post i only used 2 extruders but this issue is same with whatever numbers of extruders.
more indepth description:
right after color is finished printing, head goes up (which is not great becouse nozzle will return to this spot with new color and will leave dot of this new color) and there is a request for new filament. I remove old, insert new, continue printing. nozzle returns back to last printed position, then moves to next position to start printing with new color - and here is my issue. right befor normal printing, it extrudes, like, 5mm of raw filament in one spot, creating blob of excess material wich will later block printing head.
Thanks.
Postato : 23/05/2024 10:44 am
Dealt with extensively in:
https://forum.prusa3d.com/forum/prusaslicer/manual-multicolor/
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/acting-as-my-own-mmu
- although written for Mk3 it still applies.
Postato : 23/05/2024 4:16 pm
1 persone hanno apprezzato
Matej
(@matej-3)
Utenti
RE: (multycolor) excess material extruded after every filament change
Must have missed it first time a read that thread.. Thanks.
it seems like this solved my issue:
Posted by: @mgtarallo (note: on page 4, just that important part)
Prusa Slicer under > Printer Settings > ExtruderChange section close to bottom "Retraction when tool is disabled" to 0 to disable it(the number 4 may be present there)Repeat step for any other extruders listed
Postato : 24/05/2024 5:47 am
