MK4 Squeaky Extruder
I made a Prusa MK4 from a kit I received this year; late January, 2024. I have been enjoying the printer quite a bit, and have gotten over 6 days of print time in. However I've noticed the extruder can often be quite noisy with what can best be described as a high pitched squeaky grind.
It is my understanding that mid last year there were some MK4s sent out with faulty extruder motors, but it's also my understanding that the issue has since been corrected and I should expect that my kit mailed this year would have a newer motor.
I've read incorrect Idler tension could be a culprit, along with issues described here:
https://help.prusa3d.com/article/extruder-noises_2013
The Hotend assembly seems installed correctly. I don't notice any odd noises when extruding with the E-Axis. Please advise. Thanks!
RE: MK4 Squeaky Extruder
Does it make this odd (very odd indeed) noise when the extruder is moving only on the x-axis?
No, it is not restricted to one axis. However I think I have narrowed it down to PETG extruding. I've tried bumping up the temperature of PETG printing to 250c, but the noise remains. Slowing the print to 70% speed helps with the noise somewhat.
I'm having the exact sound issue here on my MK4, also a kit from end of Dez./early January. It occurs also on PETG, but I only printed the first few days in PLA, since then PETG, so I will have to try this with PLA maybe the next days.
For me, it only occurs on fast moves, usually IS sliced models, so it never is an issue on the first layer for example - fast paced long lines on the other hand, it rattles like your mp3. I'm just not sure if it is the extruder (due to fast gripping/extruding the petg or a gear issues with not enough grease combined with high speed use) or if it could be PETG on PETG and a strange way of squeaking. Given all 4 possible directions with x/y, I had cases, where it only makes this sound in 1 out of the 4 possible directions (brim of a box), so it could be some residue on my nozzle colliding with the last layer of PETG and the residue is only applied on one "corner" or side of my nozzle.
Has anyone had a fix for this? Mine just started squeaking and I've been using it since January '24 with no issues. Lube the gears somewhere or something? I'm guessing it's just maintenance, but I'm not sure which part of the hot end to target.
Update: I changed filament and it went away, so in my case it looks filament-specific. Thank you
Update: I installed the upgrade to the MK4S and it's squeaking again. I thought the idler was too tight, but loosening it didn't help. Any insight or fixes that anyone has been able to implement are appreciated. Thank you
I upgraded 6 Mk4 to Mk4S. I am running PLA from Push Plastic. No squeaking before upgrade. One of these machines is squeaking loudly on every print. Video is attached. Any suggestions are appreciated!
Bret
