MK4 Reprints last completed print when power loss occurs
Alvin Reabow
(@alvin-reabow)
I currently live in an area that experiences frequent power outages. These outages last for 2-4 hours at a time. If the printer is on and in an idle state (i.e no print is currently running and the printer is at the main menu) and a power loss occurs, when the power returns the printer will immediately start reprinting the last print performed. I then have to manually cancel the printing. This results in constant unnecessary printing. I had an issue where I had not removed a completed print from the bed when a power failure occurred and the printer immediately started reprinting, causing a collision between the extruder and completed part. I am currently on FW 4.7.1.
This topic was modified 3 years temu by Alvin Reabow
Opublikowany : 04/09/2023 8:08 am
