Mk4 Nextruder Fan very loud
MaxasRena
(@maxasrena)
Membre
Hi guys,
just switched from a MK3 to a MK4 (new kit, sold the old one). Assembled it on the weekend and did my first few testprints the last days.
All in all a very decent printer, I LOVE the new autolevel and nozzle change process.
But the extruder fan is so much louder compared to the Mk3. Sounds like my cheapo solder fume extractor. Why that?
I get it, the Delta fan has more air throughput than the Noctua, but is this really neccessary? I'd rather get a silent replacement for this turbine 😉 Any of you got specs of how much air movement is needed for the nextruder? Or is there another clever solution against the noise?
FYI I already got it in a kind of case (compartment in my office shelf with a door). But its still quite noticeable and a bit annoying while working on other stuff - yeah, got only one office.
Cheers
Max
Publié : 18/07/2023 7:30 pm
1 personnes ont aimé
w huson
(@w-huson)
RE: Mk4 Nextruder Fan very loud
Hello @maxasrena. I have been running the MK4 for more than 2 month and my fans are quiet as a mouse. Better get in touch with support and ask for a replacement fan. This is not as it should be.
Publié : 18/07/2023 9:16 pm
2 personnes ont aimé
Shushuda
(@shushuda)
The extruder fan will change its RPM based on the heatbreak temperature. There's a thermistor in the heatsink for that. We've had a very hot week recently and my extruder fan was going at 100% all the time, very loud but regular fan whoosh. Today it's been relatively cool and the fan was going way slower. I've checked the heatbreak temp in the sensor menu and there's been around 7C of difference between the hot week and today. So maybe your ambient is just high or you're printing at higher temps. As long as it sounds like a regular fan going fast, ofc, so a steady shhhhh. If there are any rattles and the like then something is wrong with the fan.
Publié : 20/07/2023 4:12 pm
MaxasRena
(@maxasrena)
Membre
No rattle, just genuine loud fan noice. Its not hot here this days, around 20-22°C in my room (enclosure is constantly open at the moment, so same there).
Printing PLA and PETG on stock settings, so nothing exeptional. Basically the same settings and kind of prints I used with the MK3 before.
I will measure the noice level with a dB-Meter I am going to borrow soon. We will see then.
Publié : 20/07/2023 4:17 pm
Cloud1983
(@cloud1983)
Do you have a Video of we can hear it. I think the loudness of your Fan is  normal.
Publié : 21/07/2023 11:18 am
Lorien
(@lorien)
Membre
Mine is also a lot louder than the MK3S i have. But it is not the Nextruder Fan it is the Print Fan running at 100% that is quite audible.
Publié : 22/07/2023 11:40 am
Magnus
(@magnus-2)
Mine is also loud. All movements and extruder is very quiet, but the fans is loud. I dont think its the nextruder-fan, since my is starting to get loud after a couple of layers.
Is there any way to test the fans at different speeds without printing? Also, what temp should be consider as "normal" for the heatbreak?
Publié : 24/07/2023 11:20 am
mike2060
(@mike2060)
There you go. It is loud af. Dick move on Prusa's part to go for molex click-mate connectors, they are hard to buy and usually need to order in bulk.
Publié : 11/05/2024 11:06 am
Alex
 Alex
(@alex-40)
Membre
My heatbreakfan is also going to 100% shortly after I start a print. It's annoyingly loud. My MK3 was much quieter. Since I print only with input shaper profiles the whole machine is much louder. The days when the Prusa was quiet are probably over :-(. Luckily my printers are in a separate room. But it's extremely annoying.
My personal opinion is that the heatsink design is not very effective. How can it be that even with PLA at 220°C the fan is constantly running at 100%?
@mike2060: About the molex connectors. At rs-online they are quit cheep. 10 pieces for about €2.00 (cheaper if you buy more).
Publié : 21/05/2024 1:11 pm
Comp
 Comp
(@comp)
Have you guys figured out what's causing the fan going full blast? I even had problems printing PLA, because it cools it too much and the nozzle clogs.
Publié : 10/03/2025 12:12 am
