MK4 does not show object preview after update to firmware v. 6.1.2
[Rozwiązany] MK4 does not show object preview after update to firmware v. 6.1.2
Thombo
(@thombo)
After updating my MK4 from firmware 6.0.4 to 6.1.2+7894, printer stopped showing object images while printing.
Settings in Prusa Slicer under "Printer" -> G-code-thumbnails are: 16x16/QOI, 313x173/QOI, 440x240/QOI, 480x240/QOI, 640x480/PNG
(I did not change these values neither before nor after the FW update.)
How can I make the printer display the images again? Thanks for helping.
Opublikowany : 04/09/2024 8:25 am
1 ludzie polubili
Fred
 Fred
(@fred-7)
RE: MK4 does not show object preview after update to firmware v. 6.1.2
I no longer have the image either... even with software 6.1.3
Opublikowany : 06/09/2024 9:28 am
Thombo
(@thombo)
I reported the issue as bug on Prusa3D github repository after customer support did not succeed to resolve it.
Opublikowany : 06/09/2024 4:15 pm
Thombo
(@thombo)
I exported the gCode, transferred it to the USB stick directly (i.e. I put stick in my laptop) and now an image is shown! In all other cases when image was not shown I used Prusa Link or Prusa Connect for file transfer. Fred, does that perhaps work for you as well?
Posted by: @fred-7
Opublikowany : 06/09/2024 4:32 pm
Thombo
(@thombo)
Solution / workaround: Set the timing for the Print Progress Screen (Settings -> User Interface) to more than the default 30s. (Due to a current bug.)
Opublikowany : 10/09/2024 1:12 pm
1 ludzie polubili
usmcsni
(@usmcsni)
Thank you so much I have been going crazy trying to get this working
Posted by: @thombo
Opublikowany : 21/10/2024 10:41 pm
HKOCH
(@hkoch)
Thanks. I was also wondering how to get the back working. !! Now it works
Posted by: @thombo
Trust me, I'm an engineer 🙂 Always do your best. What you plant now, you will harvest later
Opublikowany : 26/11/2024 8:44 pm
