MK3,5 Prusa Connect - Connection Refused
I am trying to connect my 3.5 to PrusaConnect, however I am unable to get the printer code - I keep getting the Refused Error. I have Enable PrusaConnect in the Printer's menu. But it keeps failing every time I try. I have tried searching the forum, but did not find anything that helped. I have already tried turning the printer on and off several times with no change, Any suggestions?
Thanks in advance!
Bill
RE: MK3,5 Prusa Connect - Connection Refused
Never mind, I tried an Ethernet Connection, and it worked immediately.
Then id contact prusa and request a new esp module. Ive seen it before play up like this
