MBL at given points?
Smutje
(@smutje)
ist there any G29 command (and hopefully activated in the MK4 firmware), where I can give specific X/Y points to probe for MBL?
I want to probe on an object and a G29 P1 (3x3) probing area might also cover areas outside of the object.
3Point MBL on given points would also be great.
Thank you in advance
Publié : 24/09/2023 6:52 am
Rainer
(@rainer-2)
You would have to solve this via the Start Gcode.
In Prusa Slicer /Printer Settings/Gcode the M555 is the one that sets the mesh points.
How it works exactly I can not tell you.But maybe you will find what you are looking for.
edit:
If I am correct, M555 switches to the use of Klipper firmware.
Publié : 24/09/2023 7:43 am
