LCD UI Suggestions
addohm
(@addohm)
LCD UI Suggestions
Please add settings that toggles on\off auto-loading of models after the USB is inserted.
Also, please put the finished print (and auto-load) screen on a timer or something so that it goes back to the home screen.
Something I'd like to see is the prusalink\prusaconnect graphing on the LCD during the print.  A graph consisting of nozzle temps, bed temps, and fan speeds.  I don't need to see the model I'm currently printing and I certainly don't need to see the botched attempt at filling said model based on percentage completion.
Thanks!
Respondido : 05/04/2023 8:50 pm
1 les gusta
addohm
(@addohm)
RE: LCD UI Suggestions
I'd also like to press a button to get into the main menu (from an infographic screen), rather than the printer just sitting on the main menu all the time.  If you print from an external source like octoprint, you're only information at a glance is the tiny text at the bottom of the screen.
Respondido : 06/04/2023 2:21 pm
You do realise this is a user to user forum ?  All bugs, issues and feature requests need to go to the appropriate repository on github.  There are currently ones for the Mk3, the mini but you will have to wait a little while until Prusa makes the Mk4 public or indicates which repository should be used.
It should  appear somewhere here at some point https://github.com/prusa3d
Respondido : 06/04/2023 5:16 pm
addohm
(@addohm)
I would hope people at Prusa look at these forums, especially at a product launch, and especially because there is nowhere to report issues on their github repo.
Respondido : 06/04/2023 10:46 pm
ssill2
(@ssill2)
all github repos have the ability to have issues created
https://github.com/prusa3d/Original-Prusa-i3/issues
you should be able to create an issue there and just identify that it's for the MK4
Posted by: @addohm
Respondido : 08/04/2023 4:25 pm
