"Input current" is always negative
Me
 Me
(@me-2)
The title about sums it up. The "input current" value on my MK4 (Home - info - Sensor info) is always negative.
Does anyone else have the same issue? Is it an issue? Or is this normal?
Thanks!
Opublikowany : 03/02/2024 2:44 am
Lynn
 Lynn
(@lynn)
RE: "Input current" is always negative
Mine too.  Have you come across and decoder ring, explaining the value and meaning of these readings.  Some of them are obvious but not all.  Input Current being and example.  When I look at that value I'm think the value represents the current draw of the machine, but obviously that is not what it is sensing.
It seems kind of worthless to provide an indication, but not explain its meaning or value. I suppose it include for tech support purposes.  Who knows.
Opublikowany : 03/02/2024 1:32 pm
