HTTP 500: 500: Infernal Server Error
Kerris
(@kerris)
Failed to create a folder.
 Hello,
 I encountered a weird issue. The gcode can be locally stored and uploaded to the printer via Prusa connect; however, when I try to send it directly from Prusa slicer it produces the error. I am not even able to read the entire error message because it is too long to appear on screen. The printer is set up correctly, everything works smoothly except direct exporting/sending the gcode to the printer via the export button in Prusa slicer.
I was not able to find any settings regarding the rules how these files should be sent to the printer. Neither in the software nor in any .ini file. My guess is that it is associated with some unallowed characters in the filename during creation but cannot find any solution.
 Thanks for help.
Posted : 17/03/2024 5:04 pm
