How to manually change filament using MMU buttons at spool end?
lskdcieju
(@lskdcieju)
Utenti
Hello,
I searched the forum for an answer to this problem but didn't found one. Please point me to a topic if I was not careful enough.
Hardware: MK4, MMU3; Firmware 6.0.1, Spool Join NOT activated.
The printer detected the end of the filament in the middle of the job and asked for more, as planned. The idea now was to select the next spool by using the buttons on the MMU. However, this leads to a loop of loading filaments manually to FINDA by using the buttons, but the printer does not proceed with the job. It is waiting for new filament and the reload process stuck from the time of the first MMU button press. It did not provide any error message but waiting half the way in the filament change status message sequence.
What is the right way to handle such a situation?
Postato : 24/06/2024 4:42 pm
