Hotend fan continuously fails self-test
Page 2 / 2
digital_realist
(@digital_realist)
RE: Hotend fan continuously fails self-test
Came here from Google after just completing a new MK4 kit build as well  Only thing that failed test was the hotend fan, confirming updating to firmware 5.1.0 fixed the issue.
Posted : 28/12/2023 11:40 pm
Peter R.
(@peter-r)
Hey everyone,
I just completed assembly on my Mk4. Everything works fine, and it prints fine, but it fails the print fan test. The hot end fan passes.
However, when I want to test the heating bed, it reports it can not proceed due to a hot end fan failure.
I *think* someone made have made a booboo in the firmware. Regardless, it prints fine, and temperatures are rock solid.
I contacted support through the chat. The person advised me to 'loosen the screws on the fan'. When I reported I tried to no avail he advised :
"there might be some firmware bug causing the selftest to be too strict. I would try running a few prints to confirm that there is no error with that fan and the next firmware should solve the problem"
So that's what I will do.
Pete
Posted : 11/03/2024 7:36 am
Hi Peter, Try slackening the mounting screws a tiny bit...
then re test,
Posted : 11/03/2024 11:15 am
ChiefSmeg
(@chiefsmeg)
You beat me to it @Joantabb, I had exactly the same issue with my kit build and this was the solution that worked for me
Posted by: @joantabb
then re test,
Posted : 11/03/2024 1:35 pm
Peter R.
(@peter-r)
This is the printing fan. It is encased. Which screws do I loosen ?
Posted : 11/03/2024 2:28 pm
Steve
(@steve-4)
Easy  to troubshoot.  Don't loosen any screws.  Make sure you have the latest firmware.
1) Is the fan turning?  If yes, proceed to 2).  If no, you found your problem.  The fan is bad.  Yes, you can loosen screws to see if the fan is binding, but I never had any problems.
2) If the fan is turning, the fan has a bad tachometer.  Have Prusa send you a new fan (or get a new fan).
The fan speed is controlled by a PWM controller based on the temperature as measured by the NTC thermocouple in the heat sink.
If loosening screws makes the problem go away, the heatsink is warped, and the fan is binding.  You need a new heatsink (and maybe a new fan).  What you can do to see if the fan is binding is to remove the fan and see if the blades turn freely.  If they don't, the fan bearings are bad and you need a new fan.  If they fan turns freely when the fan is removed, but not when it's mounted on the heatsink (with the screws tight), the heatsink is warped and you need a new heatsink.  Loosening the screws doesn't fix the problem, it simply makes the fan get looser.
I had no problems with my MK4 kit, but lots of bad parts with my XL kit.  YMMV.
I have found that Prusa support leaves much to be desired.
Steve
Senior Life member of IEEE.
Posted : 11/03/2024 4:14 pm
The mounting screws I am referring to, are circled in Orange in this picture
Posted : 11/03/2024 5:38 pm
ChiefSmeg
(@chiefsmeg)
As @joantabb says - these are the screws you inserted to affix the fan. I ever so slightly over tightened mine and ended up with the same issue as you. Mine were loosened (anct I slackened the. Off and then re-tightened them more carefully) and now everything runs like a dream.
Posted : 11/03/2024 6:51 pm
Peter R.
(@peter-r)
OK, once again. His fan is a closed unit, unlike the hot end fan. Loosening it doesn’t do anything for the pressure differential  over the fan, and thus the air resistance. I *may* try removing the shroud, but I think I’ll leave well alone for a proper fix.
If the screw trick worked for this fan, I suspect you had a pinched wire.
This post was modified 2 years ago by Peter R.
Posted : 11/03/2024 8:07 pm
Michi
(@michi)
This Fan is the Partcooling Fan and not the Hotend Fan.
The Topic of this Thread is about the Hotend Fan..
Posted by: @peter-r
Posted : 12/03/2024 6:13 pm
XL beta tester for far too long
(@xl-beta-tester-for-far-too-long)
After taking on firmware 6.0.0 now all 5 head on my XL have print fan calibration errors. They look to spin just fine.
Posted : 08/05/2024 4:48 pm
poundCake
(@poundcake)
i3 printer here - fails self test after updating firmware.  replaced old, tired, and loud fan with brand new LDO "dc 5v 0.30A" fan from Printed Solid.
New fan is new, strong, and silent.  Works fine when manually telling it to spin, additionally, it seems to come on whenever the software calls on it to.
However, you guessed it, error with fan.  Unbelievable.  Confirmed the wiring was not the issue but swapping to the old fan worked.  Now my x axis is off.. again... before the fan issue it was the zed.  Great software update so far!  Pretty soon I'll be back to being able to troubleshoot the MMU (again).
Posted : 17/06/2024 3:05 am
poundCake
(@poundcake)
@JoanTabb -
It's great to know that tightening the fan can solve this issue for some people.  It helped the issue go away for me for a bit, but didn't solve it.  I had a brand new fan installed and FWIW, it was working by all observable indications.  Can I point out that it seems unlikely that for people such as myself who have a working fan, that all of a sudden starts throwing errors, I doubt it's the screws!?!
I also observe that the menu on the 'self test' changes as it throws errors, and what wasn't a problem several rounds of restarts, becomes a problem.  For me, I got into this mess trying to get the MMU2s to work.  Printer was fine, now zed, X, and print fan are all causing problems.
Any advice?
Posted : 17/06/2024 3:14 am
WRG LLC
(@wrg-llc)
I'm having this same problem with my MK4S. Worked fine for over a year and then I started getting the error last week. Cannot read the RPM, but otherwise fan works fine and prints are normal. Purchased replacement from PrintedSolid and that did not fix it. Have not been inside unit.
Is the the only explanation a bad board? Start with LoveBoard?
This post was modified 3 months ago by WRG LLC
Posted : 20/12/2025 1:32 pm
Daniel Fernandes
(@daniel-fernandes)
This was also the fix for my hotend fan RPM error calibration issue (upgrade kit MK4S>Core One+). Thanks!
Posted by: @michi
I Hello, I also had problems with the hotend fan in the self-test.I then unscrewed the fan and did the test, or held the fan by hand and then it worked.I then screwed the fan back on, but not as tight as before. After that I had no more problems.I suspect that I screwed the fan on a little too tightly at first.
Posted : 21/02/2026 10:36 pm
Page 2 / 2
