G-code error when starting a print
Hello, new MK4 owner here.
when I try to start a print, I get a G Code isn’t fully compatible. Following features are required: MMU3
If I hit the print button, the print works perfectly. What could I have configured wrong in pursa slicing software to create this error?
I can probably deal with this error, but would prefer not to see it.
all suggestions are greatly appreciated.
troy
@schwino I would assume you have selected the wrong printer in Prusa Slicer. If you do not own an MMU3, then you have installed the wrong printer profile, which would read something like "Original Prusa MK4 +MMU3", instead of "Original Prusa MK4". If you have an MMU3 available but want to do a direct feed to the extruder, avoiding the filament passing through the MMU3, then you would probably still need the Original Prusa MK4" profile as additional alternative if you switch off the MMU3 in the printer menu (this is at least how it works with the MK3S+). Slicing needs to be done for the correct choice of printer to make use the gcode works with that particular printer; however depending on the differences wrong gcode may still occasionally function.
To install the correct printer profile, choose "Configuration" in the top menu of Prusa Slicer and then proceed to Configuration Assistant, then chose all profiles applicable to your setup.
Regards
Chris
