FW 6.4.0 Print Sheet Detection failed for Satin / PA Sheet
Hello everyone,
I updated to FW 6.4.0 yesterday. I use the PA nylon sheet. Unfortunately, print sheet detection fails for both PA nylon and satin sheets. It only works with the PEI sheet. It seems to me that the thickness of the sheets is the reason for this. Has anyone else experienced something similar?
Support recommended that I adjust the gcode or use the following code for the time being:
G28 P; home all without mesh bed level P ADDED BY ME
If I have interpreted this correctly, this interrupts the homing sequence.
Basti
This topic was modified před 5 months by baszwi00
Napsal : 17/12/2025 1:18 pm
