For those with the mk4/xl xlcd cover please give advice
Hi everyone, for those with the mk4 or xl that have the uv printed xlcd cover do you think it is possible to remove the originail prusa mk4/xl sticker. I dont care if it gets damaged do you think its possible. Many thanks
The MK4 xLCD cover that came with my kit has the lettering UV printed directly onto the part - it's not a sticker.
For my MK3.9 purchase, I chose to print the parts myself, and it came with a sticker to apply to the blank part.
In both cases, I chose instead to print my own covers with the 'manual MMU' approach.
RE: For those with the mk4/xl xlcd cover please give advice
Thank you, so do you think that it would be impossible to get the uv printing off.
Why don't you just print a replacement cover removing the colour where you don't want it?
Because i wanted the cool uv printed rest and usb icon on my mk3.5 but i guess i will be printing my own if its impossible to get off.
Print those on using the one nozzle mmu method then
I have a mmu3 so ill use that if it is impossible to get off
I would have thought that would be easier and give better results than trying to separate the uv parts.
Id only take off the mk4 bit replace it with my mk3.5 sticker
