Flashing Firmware Many Times
Hi Everyone,
I'm loving the new MK4.
I've flashed the new Alpha 3 firmware and it's amazing. The print quality is amazing given for the speed savings.
The only problem so far is that the Alpha firmware currently only supports a 0.4mm nozzle and 0.2mm layer height. So I can see my wanting to swap back to a production release to have a wider selection of print options.
Should I be worried about flashing the firmware a few times while they get a more feature rich version of v5?
Veröffentlicht : 08/07/2023 7:46 pm
Updating the firmware isn't going to cause enough write cycles to cause problems with the memory.
If you updated the firmware a few thousand times then you might see problems.
Never let your printer worry you. Just buy a few Haribos and enjoy your printer.
Veröffentlicht : 09/07/2023 12:51 am
