First layer problem, after upgrade auf MK4 (ASA)
dt
 dt
(@dt)
I have upgraded my MK3s+ to the MK4.
Firmware 5.1 / Prusaslicer 2.7Printed all upgrade parts with ASA without any problems. I have warping with the MK4.
The printer is in a closed housing.
The settings are the same as for the MK3+, Polymaker lite ASA hotend 260° board 110°. I had printed 3 rolls in the MK3.
I have also already adjusted the Z-distance in the Prusaslicer -0.1mm no improvement
What would you suggest, revert to firmware 5.0.1 and install Prusaslicer 2.6?
There are supposedly problems with the 5.1
What I also notice, now I have the warping in the front, when I had problems with the MK3 it was on the left.
So I suspect the hotend fan, should I do an orifice there? Do you have any experience?
Sorry, English with translator, but in the German forum there is little.....
Napsal : 08/12/2023 10:12 am
