First layer issue
Marcus
(@marcus-5)
First layer issue
Hi!
Been printing on my MK4 with perfect result. Until recently when the printer decides to print first layer a little high...
On my old MK3, I would have done a "first layer calib...". But on Mk4 I do not know how to investigate it.
  • Had not done any updates
  • Have tried different files, new generated and old gcode (before issue occurred)
  • Have done new calibration
Prusa support whant me to: "Could you send me a photo of the first layer with one of the prints that came on the USB".
And after asking for some surgestions on what to invistigate I got answer:
"Underextruding, model, slicer settings, nozzle, filament tension, dirty sheet or nozzle, position of the spacers under the bed..."
Someone that had similar issue?
Regards
Marcus
Publié : 24/04/2024 9:10 am
Dark Helmet
(@dark-helmet)
RE: First layer issue
I have been experience the exact same issue for the past few months. It comes and goes, randomly, even when re-printing the same gcode in succession with the same filament on the same sheet (e.g., when printing a batch of five, two of them will start with the first layer too high). But it happens much more frequently with the textured sheet (PETG) than the smooth sheet (PLA).
I have tried going through the whole recalibration routine, thoroughly cleaning the nozzle, swapping sheets, using different (brands of) filament, tweaking filament settings and some other stuff I'm forgetting. IIRC it started happening around the 5.1.0 FW; I'm currently on the 6.0.0 FW.
The only solution I have found is to watch when it puts down the first layer and, if it looks too high, use the live Z adjust to lower it by 0.055. (You can switch to live Z adjust by depressing and holding the knob as soon as it says "Printing" on the LCD screen.) After I set Z height to -0.055 the first layer is perfect.
Publié : 24/04/2024 11:25 am
1 personnes ont aimé
Marcus
(@marcus-5)
I disassembled the printer head, cleaned it, put together and did the calibration. Now it's working.
We will see for how long 🙂
Publié : 25/04/2024 6:04 pm
Norman Lindsey
(@norman-lindsey)
Membre
I have the exact same problem.  I am printing with PETG and textured build plate.  It was working perfectly, and I tried to print parts for the openable enclosure that had something like 8 perimeters, and it has not worked since.  Nothing works.  First layer failures even with older models.  I've upgraded the firmware, did a factory reset with 6.0.0 firmware, reset defaults in PrusaSlicer to no avail.  I'll try thoroughly cleaning the nozzle and see if that helps.  The live Z adjustment is creative; maybe that will work.
Publié : 10/05/2024 2:29 pm
Brian
(@brian-12)
The nozzle needs to be cleaned between every print, especially with petg which notoriously sticks to the nozzle.
If your nozzle is dirty it will mess up the bed probing because it'll be probing on the plastic build up on the nozzle and not on the nozzle itself, creating your first layer issues.
Preheat the nozzle to printing temperature and lightly brush it clean with a brass brush.  I have a good first layer every time by doing this.
Publié : 10/05/2024 4:22 pm
Dark Helmet
(@dark-helmet)
Posted by: @brian-12
I see this theory put forth pretty much every time someone brings up the first layer issue. And it very well may be a problem for printers with dirty nozzles. But I keep my print head clean and it does not matter. Sometimes filament will ooze before the bed leveling and get stuck between the nozzle and the bed during leveling and the first layer will be perfect. Other times a sparkling clean nozzle will produce an absolutely terrible first layer.
Whatever the cause, the first-layer problem has nothing to do with the nozzle making clean contact to the bed during leveling. It comes and goes and the only reliable solution I have found is lowering the nozzle via live Z adjust right before the first layer. I do, however, think it is related to the load cell since I never, ever have a problem with the first layer on my MK3.
Publié : 10/05/2024 6:33 pm
Brian
(@brian-12)
Just reporting my experience.  When I first got the MK4 I had a few bad first layers.  Now probably 500+ prints later making sure the nozzle is clean I've had zero first layer issues.  You can't really compare it to the MK3 because your nozzle could be dirty and it wouldn't matter.  It's a different mindset when your probing. with the nozzle.
Maybe you have a bad load cell, but I'm guessing 95% of the time people have problems is because they didn't clean the nozzle.
Publié : 10/05/2024 7:21 pm
Marcus
(@marcus-5)
Hi again!
Now the problem is back again..! And I also starting to get the same problem on my other MK4 !!
Tried contact the Prusa support. But The help I get from them is so time consumin my mind explodes. Both printers are standing in a closed heated Cabinet and haven't been used more than some hours.
II really miss my old MK3 printers.
Tried cleaning nozzles of course and I think lower the printer head by 0.055 every time the printer starts is a hassel.
/M
Publié : 11/05/2024 7:08 am
riethmueller
(@riethmueller)
I've a similar problem with PETG and the textured sheet and I assume this isn't really a cleaning issue. My nozzles are always clean on the tip and the cone. I use a silicone sock but I don't thinks that this is the problem when I read this thread. Is it possible that the cable to the heater will influence the result? Due to the fact that I often switch the whole head I don't lay the cable careful in the cable slot. But this don't explain why PETG/textured sheet often affected and not PLA.
Publié : 20/05/2024 7:51 am
LiorCh
(@liorch)
Membre
I have the same first layer issues with the MK4 printing PETG. I also tried contacting support, but the only thing they suggested is making sure the nozzle is clean, and making sure the nozzle is pushed all the way through.
Sometimes cleaning it well does help, but usually the layer is still too high. I was hoping a firmware update would help, but it didn't.
The only way I found to get a perfect first layer is by adjusting it manually on every print (by about -0.1)
I was really hoping the Mk4 automatic first layer calibration would finally rid of the need to do the z offset adjustment, but it's actually a worse experience than the Mk3...
Publié : 21/05/2024 8:32 am
Heesh
(@heesh)
Membre
Hmm I have the exact same issue. I'm trying to print PETG on the textured sheet and the issue arose just a few prints ago. I was printing in the same exact setup from the beginning without a problem. Yes I'm cleaning the nozzle / sheet. I don't know if the issue started with updating my firmware / configuration templates in the slicer.
Ce message a été modifié il y a 2 years par Heesh
Publié : 01/06/2024 12:12 pm
