First 3D Printer, Print Sheets and Nozzles
William Rowe
(@william-rowe)
I'm going to order the MK4. It will be my first 3D printer. There are options for additional print sheets: textured and satin. I'm going to print gridfinity parts to start. Would I need a different one for this application or is it useful to have them on hand? I'll start with PLA as that seems to be a general consensus in a gridfinity post on the subject.
A 0.6mm nozzle is also recomended. I found a nozzle page on the web site, but no mention of 0.6mm. Is this something I get somewhere else?
Napsal : 07/04/2023 1:58 am
Robin_13
(@robin_13)
RE: First 3D Printer, Print Sheets and Nozzles
I just got my first 3D printer and got a second smooth sheet and a satin and textured as well.  As I learn more, I think I should have gotten a second satin sheet instead of the smooth sheet, but I don't have enough experience to confirm that.  What i did was look at the filaments I want to print with at the time.  I have projects that will use both PETG and ASA so that was my basis.
I have seen some interesting videos on using a 0.6 nozzle and may got that way for many of my prints.  Not sure about the MK4 nozzle.  The MK3s+ uses a standard nozzle and I have ordered other sizes and hardened nozzle for one project.
BTW, the gridfinity look interesting.
Napsal : 07/04/2023 4:59 am
jkavalik
(@jkavalik)
The 0.6 and other nozzles should become available later for MK4, and with the adapter any other standard nozzle can be used.
As for the sheets I did not yet get my hand on the satin one. The smooth sheet has very good adhesion for PLA and I use it most of the time. The "downside" is mostly cosmetic - the bottom of the print is smooth (with the first layer lines mostly clearly visible) and the rest of the print is not. So I have the textured sheet for cases where I need the bottom to look better (printing something with my logo upside down etc.)
Napsal : 07/04/2023 8:13 am
William Rowe
(@william-rowe)
I order one of each sheet and will wait on the nozzles.
Thanks for the help
Napsal : 07/04/2023 4:55 pm
addohm
(@addohm)
This will help...
Napsal : 09/04/2023 9:29 pm
