Firmware upgrade not happening
dcorbin13
(@dcorbin13)
I'm trying to upgrade my firmware,  It's currently running 6.0.2+. and I'm trying to upgrade to 6.2.4.  I download the .bbf file.  It's not even a .zip.  I've reformatted the USB drive using FAT and Extended FAT (MacOS).  Copy the file to it, eject it.  Insert into the printer and press reset.  It never offers me the chance to flash the ROM[sic].
Not sure what else I should be trying.
Publié : 01/06/2025 2:31 pm
JP Guitars
(@jp-guitars)
RE: Firmware upgrade not happening
I think the stick needs to be FAT32.
But you can flash it from Connect directly,  or copy the file over in PrusaLink and restart the printer
Publié : 01/06/2025 2:56 pm
JP Guitars
(@jp-guitars)
Publié : 01/06/2025 2:57 pm
JP Guitars
(@jp-guitars)
I think it needs to be Fat32
Or you can do it from Connect or copy the file over using Link
Publié : 01/06/2025 2:59 pm
JP Guitars
(@jp-guitars)
Publié : 01/06/2025 3:00 pm
JP Guitars
(@jp-guitars)
Publié : 01/06/2025 3:02 pm
dcorbin13
(@dcorbin13)
"MS-DOS (FAT)" is apparently FAT32 on MacOS.  My printer is not connected to Connect, and attempts to change that fail with a TLS error (which docs suggest means an NTP problem that I can't find a reason for).
Publié : 01/06/2025 3:13 pm
JP Guitars
(@jp-guitars)
Sorry about multiple posts, kept getting 504 error which implied it had not posted
Publié : 01/06/2025 3:29 pm
Sembazuru
(@sembazuru)
If you put a gcode (or bgcode) from PrusaSlicer on your thumb drive, does the printer see it? (Trouble shooting to see if the issue is with the printer recognizing the thumb drive or just the .bbf file. The .bbf file is what the printer's firmware should be expecting for a firmware upgrade.)
See my (limited) designs on:
Publié : 02/06/2025 9:36 pm
ssmith
(@ssmith)
Firmware 6.1.2 brought a new boot loader, maybe need to install 6.1.2 before jumping to 6.2.4?
Publié : 02/06/2025 11:32 pm
dcorbin13
(@dcorbin13)
Posted by: @sembazuru
It turns out, no. I reformatted with a linux system and it worked.  Thanks.  Not sure what's up with MacOS, because it's been interoperating with MS crap for years.
Publié : 03/06/2025 10:51 am
1 personnes ont aimé
