Firmware 5.0.0 fail's selftest
Qubiki 3D
(@qubiki-3d)
Firmware is working. But I have bug error on my two mk4 printers failing X assis test's. And its not even starting the Y and Z axxis test.Earlier on one printer witch was assembled week ago. All test's was passing on 4.7.2 firmware but after update to 5.0.0 is failing
Publié : 18/09/2023 8:17 pm
3D Attic
(@3d-attic)
RE: Firmware 5.0.0 fail's selftest
I had  a similar problem also that the self test failed, I reverted back to 4.7.2 and ran the self test again it it worked. I 'm going to wait until the stable release of the firmwre comes out and Input Shaper is fixed.
Publié : 19/09/2023 8:24 pm
Peter - Rostocker Printen
(@peter-rostocker-printen)
I had this issue with the old firmware as well. My issue was, that the right cover on the extruder was not sitting perfectly and was hitting the end stop to early. I just removed during self test, and then is was ok. The self tests uses around 1mm more movement than the normal maximum range of the x axis.
Publié : 23/09/2023 7:34 pm
