Filament stuck inside Nextruder nozzle help
JMH714
(@jmh714-2)
Last night, I was doing printing and noticed it was printing air. I checked if the spool was jammed, it's not jammed. So, I unloaded the filament and re-insert it. It did not allow me to autoload the filament.
I went ahead and remove the nozzle and insert the needle in and it stopped short. Then I inserted the filament through top tube and measure how far inside it stopped.
It seems like the piece of filament is stuck between red lines.
How can I get it out? Am I out of luck?
Veröffentlicht : 11/05/2024 6:56 pm
JP Guitars
(@jp-guitars)
RE: Filament stuck inside Nextruder nozzle help
Blow torch, burn it out
Veröffentlicht : 11/05/2024 7:23 pm
Thomas
(@thomas-14)
With some kind of wrench, hold it in a gas flame. For instance the gas stove in the kitchen.
It will liquify and run out of the tip. You can use a 1.5 hex key to push it out if needed.
Veröffentlicht : 11/05/2024 8:14 pm
JMH714
(@jmh714-2)
Thank you, guys.
Managed to get it out with your advices. I never had a long nozzle before and I wasn't sure how to remove it. 😬
Veröffentlicht : 11/05/2024 9:19 pm
JP Guitars
(@jp-guitars)
It's Scary the first time you do it,  isn't it.
Veröffentlicht : 11/05/2024 9:25 pm
