Export Full Printer Profiles
ShaneTalksTech
(@shanetalkstech)
I had to do a fresh install on my laptop and after installing Prusa Slicer, The profiles for the original MK4 are no longer there. The options that I have are for MK4S and the MMU3 with Input Shaper.
This is unfortunate because I prefer the quality and detail prints over something that prints fast.
How do I export the entire printer profile with the different print settings for it from one computer to the other. I tried to export printer profile but it fails to load on the laptop. I am not sure if I am doing something wrong.
Thanks for the help
-Shane
Best Answer by ShaneTalksTech:
I have actually found what I needed. The Original MK4 Profile has been moved down to the Legacy Printers section.
Postato : 06/12/2024 7:35 pm
RE: Export Full Printer Profiles
Profiles installed by the wizard have to be chosen on new installs by running through the config wizard again. Unless you literally copy the entire folder over from machine to machine.
For custom configuration profiles you use export config bundle and then import config bundle on the new machine. So if you want to move a-edifice ones that were originally system ones just make your own copies with your own names and then they will be included in the export config bundle.
Postato : 06/12/2024 8:43 pm
ShaneTalksTech
(@shanetalkstech)
I found a page on the Help section of the website and followed the instructions but it does not work. It says '0 Profiles imported successfully.'
I am not sure if I am doing something incorrectly. I wouldn't think so because this should be pretty straightforward, but it is not working for me.
Postato : 07/12/2024 10:25 am
ShaneTalksTech
(@shanetalkstech)
Postato : 07/12/2024 10:45 am
1 persone hanno apprezzato
