End g-code don't end at requested position
JanP
 JanP
(@janp)
Utenti
I use the following End g-code in Pruse Slicer 2.9.3 and my MK4 (firmware 6.2.6+8948) . The printer moves to the requested position G1 X50 Y210 Z170, but afterwards the printer head moves in the x-direction to the right position. Is it my End g-code or does the Printer or software have other settings that changes this?
This is my End g-code entered in the Prusa Slicer program.
; === Prusa MK4 End G-code ===
; Lift nozzle a bit to avoid hitting the print
{if layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+10, max_print_height)} F720 ; lift head{endif}
; Turn off heaters and fan
M104 S0 ; turn off nozzle heater
M140 S0 ; turn off bed heater
M107 ; turn off fan
; Move head to safe park position: center (X=125), back (Y=210), Z=170
G1 X50 Y210 Z170 F6000
; Small pause (optional)
G4 ; wait
; Reset firmware settings
M900 K0 ; reset Linear Advance
M142 S36 ; reset heatbreak target temp
; Disable motors
M84 X Y E
; === End ===
Postato : 13/09/2025 12:00 pm
JanP
 JanP
(@janp)
Utenti
RE: End g-code don't end at requested position
I have also tried to use that standard End g-code with a change of X=120 (and closed Pruse Slicer, open the program again and checking the g-code), but the printer head are still going all the way to the right (X=220).
I can still see, that the changes of  X have a influence in the head movement, but afterwards the head moves to X=220.
The code now the following:
{if layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+1, max_print_height)} F720 ; Move print head up{endif}
M104 S0 ; turn off temperature
M140 S0 ; turn off heatbed
M107 ; turn off fan
G1 X120 Y170 F3600 ; park
;{if layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+23, max_print_height)} F300  ; Move print head up{endif}
G4 ; wait
M900 K0 ; reset LA
M84 X Y E ; disable motors
; max_layer_z = [max_layer_z]
Postato : 13/09/2025 1:30 pm
JanP
 JanP
(@janp)
Utenti
Information to others that have the same problem: The first versions of Mk4 firmware don't handle the "End g-code" correct. If you ask Prusa for help regarding this, they don't support g-code at all, even if it is their firmware that don't work correctly. I found out myself, that an update of the Mk4 firmware solved the problem and now the "End g-code" works.
Bonus information: I upgraded the Mk4 firmware to version 6.4.0, but at other users have experienced, this new firmware have an other problem. When turning the Mk4 on, it is not starting but show an error screen. Then you have to press the reset button and then the Mk4 starts correctly.
Postato : 07/01/2026 6:31 am
JanP
 JanP
(@janp)
Utenti
Information about firmware upgrade to version 6.4.0: I have removed the firmware file (.bbf) from the USB stick, and it sems to solve the problem (Mk4 will not start). This was not a problem with previous firmware files (not mentioned in the Prusa instruction). I will get back to this post after testing it for some weeks.
Postato : 07/01/2026 7:45 am
