Enclosure door hits LCD on external mounting ...
Praefectus
(@praefectus)
The instructions for the MK4 show different mounts on the LCD than what come with it ... I suspect these get the LCD lower so the enclosure doors will close?  I'll go look to see if I can find any solutions (else I'll have to make my own), but I certainly couldn't have been the first to have this issue ... how did you guys solve the issue?
Napsal : 03/06/2024 12:50 pm
cupajoe24
(@cupajoe24)
My enclosure came with new mounts for the LCD, did you check for that? (I assume here that you're talking about the official Prusa enclosure?) Or is your situation that you previously had the enclosure with an MK3, now you're putting in an MK4 and don't have the different mounts?
Napsal : 03/06/2024 3:28 pm
Praefectus
(@praefectus)
RE: Enclosure door hits LCD on external mounting ...
No, they must have "missed" including them with the enclosure ... you can see others have had the same issue:
https://www.printables.com/model/861217-mk4-lcd-supports-for-prusa-enclosure
It's pretty embarrassing really for Prusa.  Spend 2 grand on everything and all upgrades, and can't finish the build ... boo.
Napsal : 03/06/2024 4:12 pm
Praefectus
(@praefectus)
Yes, sorry, I was talking about new purchases of the MK4 and the Original Prusa enclosure ... I didn't get the secondary mounts that allows for external LCD mounting and the ability to close the enclosure doors.
Napsal : 04/06/2024 5:42 am
