Dual Filament position
DarkTeck
(@darkteck)
Just got the dual tool unit and started printing . Not sure how I feel about the filament roll position on the side of the machine . The upper spool has a perfect alignment . The lower spool seems to have a tug on the PTFE tube and seem over time it may cause premature wear and tear . Worried this may cause filament drag considering there’s a good 2 foot plus of filament that has to get loaded to reach the extruder . Seems lime it screams for a little adapte with a bearing and wheel to ease filament in .
Napsal : 02/07/2023 9:31 pm
1 lidem se líbí
dvillalba3d
(@dvillalba3d)
RE: Dual Filament position
I think you are right...
Napsal : 07/07/2023 12:47 pm
The spool positioning on the XL feels very half baked. I'm in the process of routing it from a shelf above the printer with some PTFE tubes. Works fine for the single tool unit I have--waiting for the additional tool heads to become available.
Napsal : 07/07/2023 7:41 pm
w huson
(@w-huson)
This is an XL thingy in the MK4 sub. Can you move it there yourself? 😜
Napsal : 07/07/2023 8:20 pm
