Display problem: flickering, blanking, corruption
EricB
(@ericb)
Our MK4 is about a week old, assembled from the kit, and we've had great success with our first few prints.
After several days of flawless behavior, I find the display is sometimes blanking, flashing white and showing corrupted (partly-drawn) info. When this happens, the changes are irregular, maybe once a second on average. Other times, the display is fine for hours at a time .
The printer continues to print normally when this happens.
From my limited experience with little displays, I'm guessing that the display has a flaky power connector.
Is this a problem others have seen?
Opublikowany : 22/06/2024 4:16 am
EricB
(@ericb)
RE: Display problem: flickering, blanking, corruption
To more details:
The splash screen seems to always be fine. Sometimes the problem starts right afterwards.
When it was displaying normally, I tried gently wiggling the ribbon cable going to the display. This did not trigger any display problems.
Opublikowany : 22/06/2024 2:54 pm
