Dimensions MK4
Rainer
(@rainer-2)
Dimensions MK4
can someone might measure how much the MK4 needs in depth?It should be in a printer cabinet and it becomes tight.
The official measure is 550mm
So I would need the measure of the heating cable when the bed is at the back, up to and including the display. That should stay possible.The other dimensions would also be nice but not absolutely necessary.
Thanks very much .
Best Answer by w huson:
Sorry nobody answered you sooner. 550mm is indeed the measurement.
Postato : 24/06/2023 2:58 pm
Rainer
(@rainer-2)
RE: Dimensions MK4
Nobody has one MK4? 😥
Maybe I could have spent the waiting time with improving the printer cabinet.But I only leave it for suspected.
Postato : 25/06/2023 3:12 pm
w huson
(@w-huson)
RE: Dimensions MK4
Postato : 25/06/2023 4:02 pm
Rainer hanno apprezzato
Rainer
(@rainer-2)
RE: Dimensions MK4
Thanks a lot, I wasn't sure if Prusa considered the heatbed cable.
Postato : 25/06/2023 4:09 pm
Neolker
(@neolker)
Utenti
RE: Dimensions MK4
Hi, MK4 is almost the same like MK3S+, only add 3 cm in X axis.
Postato : 27/06/2023 8:09 am
