[Gelöst] Dimensions MK4 Build plate
Alega
(@alega)
Mitglied
Hi all,
I've ordered my MK4 kit under the impression that the build volume of 250x210x220 is written as XYZ or maybe LWH, but am increasingly worried that the 250mm refers to the Z-axis instead of the build plate... Especially since the PEI plates are compatible with both MK3 and MK4.
So I wanted to ask (1) what are the build plate dimensions, (2) how to read the MK4 build volume and (3) whether it's just me who finds it prone to confusion?
Cheers
Veröffentlicht : 28/08/2023 1:43 pm
Alega
(@alega)
Mitglied
RE: Dimensions MK4 Build plate
My apologies. I just discovered that the MK4 build volume is documented as XYZ with 250x210x220 and that the Z axis has indeed +10 mm from the MK3 build volume of 250x210x210... Not sure how I missed it, but my bad! Topic solved
Veröffentlicht : 28/08/2023 7:45 pm
The printable area of the build sheet on both the Mk3 and Mk4 is 250 x 210 mm - there is a margin outside this and the actual plate is a little larger.
Veröffentlicht : 28/08/2023 7:53 pm
