Difference between Hardened Steel and other sheets?
MikeH
(@mikeh)
How does the "Hardened Steel Sheet" differ from the other print sheets?  Is it just another name for the "Smooth PEI Sheet"?
Ce sujet a été modifié il y a 3 years par MikeH
Publié : 18/10/2023 10:01 pm
RE: Difference between Hardened Steel and other sheets?
Link? I don't see a hardened steel sheet in the shop?!
Publié : 18/10/2023 11:01 pm
MikeH
(@mikeh)
Damn!  That was supposed to be "Heatbed Steel Sheet", which is what two of my sheets are labeled.  I suppose that is the same thing as the "Smooth Steel Sheet" from this link:
https://help.prusa3d.com/article/smooth-steel-sheet_196550
I have 3 plates labeled "Heatbed Steel Sheets" and one labeled "Smooth PEI Sheet",  The former may have been included or ordered a year ago or two for my Mk3 printer and I'mm pretty sure that the latter came with my Mk4 printer.
Publié : 18/10/2023 11:16 pm
Sounds  like a reasonable assumption that they're the same as smooth.
Publié : 18/10/2023 11:25 pm
