consistent under extrusion with 0.6 Nozzle
Chris_KA
(@chris_ka)
I get really good results with the MK4 and the stock nozzle 0.4. I also have a 0.6 nozzleX and as others already pointed out the diameter seems a bit on the narrow side of 0.6. I get a consistent under extrusion on all prints. So I obviously can tweak the Extrusion Multiplier parameter in the filament settings to compensate this.
But is this the right thing to do. I want to change something related to printer settings which takes effect for all filaments I am using. Otherwise I need to tweak all my filament settings for the 0.6 nozzle and change all of them back when I swap to the 0.4 nozzle again.
I have to admit that I am not yet familiar with the inheritance rules of settings in the Prusa slicer. Any advice to do this the right way is highly appreciated
Respondido : 07/10/2023 9:02 am
Chris_KA
(@chris_ka)
I think the root cause is the coating. There is another post here where the same effect is seen with an obsidian nozzle 0.6 which also has a coating. This seem to narrow the diameter a bit which needs to be compensated in the printer settings so that we can use the same filament settings for different nozzles.
Respondido : 07/10/2023 9:15 am
TJH
 TJH
(@tjh)
RE: consistent under extrusion with 0.6 Nozzle
In slicer, look under "Printer settings", then "extruder"
You can enter a nozzle diameter in there (need to save as to a new printer definition)
I don't know if this actually changes the slicing, but it seems like it should.
I have on an Obxidian 0.6 nozzle too and it looks to me like it under-extrudes. With a smooth sheet, the print still works OK. With a satin sheet it's hit or miss (mostly miss)
Respondido : 08/10/2023 2:01 am
Chris_KA
(@chris_ka)
Thanks for your comment but that is not my point. I use a printer profile for a 0.6 nozzle. There the nozzle size is already entered correctly. But I still need to enter an ExtrusionMultiplier in the Filament settings to compensate. I don’t think that I should enter 0.59 to compensate for this.
Respondido : 08/10/2023 8:53 pm
