Connectivity Problems After Latest Firmware Update (5.1.2) on MK4
shvs
 shvs
(@shvs)
Hello everyone,
I recently updated my MK4 firmware to the latest version and encountered some connectivity issues with PrusaLink/WiFi. The problem is that the WiFi icon appears on the display, but it's greyed out. Additionally, in the WiFi settings menu, the IPv4 Address shows as N/A, preventing me from connecting it to Prusa Slicer.
Has anyone else experienced this issue with the latest firmware update? I've double-checked and uploaded the credentials correctly, but even after waiting for some time, there's no apparent update or resolution.
Any insights or suggestions would be greatly appreciated. Thank you!
Opublikowany : 17/01/2024 8:22 am
shvs
 shvs
(@shvs)
RE: Connectivity Problems After Latest Firmware Update (5.1.2) on MK4
Problem solved, I skipped the step where I had to flash the Wifi module. This step appears right after flashing the firmware, and then right after booting the wifi prompt appears, I pressed abort.
Opublikowany : 17/01/2024 8:40 am
1 ludzie polubili
