Color change should be like filament unload/load
The filament unload/load is pretty simple and doesn't require confirmation button presses.
I'd like the color change operation to be exactly the same.
Instead color change has confirmations, "did you remove the filament?" and "did you insert the filament?".
There's a sensor that detects that so don't bother making me press the button twice.
Postato : 05/02/2024 2:20 am
2 persone hanno apprezzato
