Bed levelling causes this damage to the PEI sheet
tdk408
(@tdk408)
Before printing, the printer nozzle pecks at the PEI spring steel sheet a dozen times. Each place is now damaged. It seems the hot nozzle is damaging the PEI in those specific places. Each mark is a donut the dimensions of the nozzle tip. In the photo, the white material in the row of marks is the PEI coming off.
I understood that a load cell was supposed to stop the vertical motion when the nozzle touches the bed.  But then why this?
Prusa support wants me to check the nozzle position, the firmware and the spool position. I don't see how any of these could cause this damage, particularly if the load cell is working.
Any ideas?
Postato : 16/01/2025 8:33 pm
ManelTo
(@manelto)
RE: Bed levelling causes this damage to the PEI sheet
The same thing happened to me last week. I had to remove the nozzle and reattach it and it started working properly again. But the PEI is damaged. 😥
Sorry for my poor English. I try to do my best.
Postato : 16/01/2025 8:57 pm
JP Guitars
(@jp-guitars)
I can see that happening if the nozzle is loose as it will continue pressing until the slack is taken up but cannot see how the firmware or spool position would make a difference.  My gut reaction though, is a faulty/mis-calibrated load cell.
Postato : 16/01/2025 9:07 pm
tdk408
(@tdk408)
I don't understand. If the load cell works, it doesn't matter if the nozzle is loose.
Lets say there is 10mm of play. the z axis will continue to descend until the slack is taken up. At this point, the load cell still triggers once the nozzle touches. Even so, no damage.
Am I not seeing this right?
Postato : 18/01/2025 1:58 am
Mike B
(@mike-b-3)
When you start printing, the nozzle will be 0.2 mm (whatever your layer height is) too low (i.e. touching the bed instead of one layer above it) but going horizontal instead of vertical.  Dragging the hot nozzle across the plate will cause damage.
Postato : 19/01/2025 10:02 pm
tdk408
(@tdk408)
Damage caused by bed calibration
Posted by: @mike-b-3
I didn't know that, Mike. Thanks. But it doesn't address my concern.
I am describing a grid of spots which are clearly evident on prints. (See the attached image.)
This damage in exactly the places where the nozzle touches during the calibration process. When I put the sheet under my microscope, I see the PEI coating has been mashed away in the clear shape of the tip of a 0.6mm nozzle.
Check your smooth sheet and tell me if I am alone.
Cheers, Tom
Postato : 24/01/2025 3:48 pm
Mike B
(@mike-b-3)
Posted by: @tdk408
Cheers, Tom
Unfortunately I rarely use the smooth sheet - I've been using the satin sheet almost exclusively for PLA, PETG, and PC.  My PEI sheet has no marks like this but it could be something that develops over time...
Does it seem like the nozzle is being pushed too hard into the bed during the levelling process?  Perhaps the calibration of the load cell is to blame - putting too much pressure on it?  Just trying to come up with some ideas...
Postato : 25/01/2025 7:12 am
tdk408
(@tdk408)
Sorry I am answering so late. I cant tell if the load cell is "pushing too hard".
I see the damage only on the glossy original Prusa sheet. Either the textured sheets hide the damage, or I have too many other things to worry about. (shrug)
Tom
Postato : 28/08/2025 8:05 pm
Mike B
(@mike-b-3)
All I would suggest is re-do the load cell calibration.  You only need a very light finger tap on the tip of the nozzle when it asks you - it doesn't take much to be detected and that will minimize the pressure on the build plate.
Postato : 28/08/2025 9:00 pm
ar-men
(@ar-men)
Utenti
Hi Tom,
have you resolved somehow your problem with the PEI being touched/damaged ? I have assembled core one kit and I am seeing the same problem. During the homing / init phase ... when the pei goes up it hits the nozzle, just for the first time ... all other attempts are soft ...
Please let me know.
Thank you.
Postato : 22/12/2025 5:57 pm
