Are some of the preloaded printer files incompatible with the MK4?
AthanT
(@athant)
Membre
Hello! My son has a MK4 that seems to work correctly (except for the filament sensor which we turned off). My question is this; “Are some of the preloaded printer files corrupt or incompatible with the MK4”? Let me explain, he can print the Rocket Engine fine without any issue using different colored PLA as well as any of the tools and several other items. However, when he attempts to print some of the more intricate items like the “Adamantium Claws”, the printing begins fine, but as it moves to the right side of the platform it seems to me that the position of the extruded tip is too far from the bed and it does not deposit the filament. The firmware is up to date, belts are tensioned and the machine platform alignment seems to work properly”. It’s just when this file is used to print the printer head seems to move up a fraction of a millimeter and the problem starts.
Is the bed warped? Doesn’t the bed alignment take this into consideration? Are these files not compatible?
I don’t know what to tell him and he is frustrated that he spent his summer savings on this printer and it is so disappointing for him. Any help or suggestion would be GREATLY appreciated! Thanks
Publié : 28/02/2025 2:44 pm
