Aligning text to faces of a Solid in Prusa Slicer 2.6.1
Geosq2000
(@geosq2000)
Utenti
I found this new feature in Prusa Slicer to add text after I import the step file.  I was able to add the text but manipulating to the the desired location on one of the solid surfaces is next to impossible based on my limited knowledge of the options. Any tips would be very much appreciated.
Postato : 19/09/2023 2:13 am
carlmmii
(@carlmmii)
RE: Aligning text to faces of a Solid in Prusa Slicer 2.6.1
You should be able to manually enter the coordinates/size of the text in the lower-right options.
If the model features are preventing easy access to the place where you're entering text, it might help to add a cut to the object (select the "split to parts" so it retains the geometry of the whole object), temporarily move the piece that's in the way, then move it back once the text is in place.
Postato : 21/09/2023 3:40 am
