.25 Nozzle X with V6 Adapter CLOG
My Prusament PLA GB absolutely hates when I mess with extrusion multiplier at all, mostly going under. Seems to always cause clogs. Anyhow, wasn't at home to catch this one. Simple up heat wasn't working, and the filament was broken. To clear I heated up to 265, powered off "dropped" the nozzle and pulled from the top with pliers. Works.
Sticking with my Polymaker Poly Terra and planting some trees.
Just in case you need it.
Be careful though, she's a hot mama.
Opublikowany : 08/09/2023 6:21 pm
