Z lift before a filament change
chaoscrack
(@chaoscrack)
Hello
The time when I want to change the filament is, when I switch on the printer (MK4 6.04) or after an ended print. During a print I do it with the slicer. In my opinion the printer head is always lifted when I want to change the filament.
Why the printer does a big extra movement bevor it unload the filament. Just a small move form 1 or 2 mm would be enough. If your last print was very high, it could be that the Z-axis run into the end position (not nice).
Is there a possibility to reduce the parameter?
Thanks
Postato : 15/08/2024 9:36 am
