WIFI will not stay connected, MK4 + FW 6.0.0
threedjd
(@threedjd)
Utenti
After updating MK4 to FW 6.0.0, updating Wifi module, and reconnecting to wifi AP, the wifi status continually flips between "connected" and "no AP" every 2-3 seconds.
I have:
  • reset the printer
  • power cycled
  • recreated the wifi ini file for two different networks
  • updated the wifi module again
  • double-checked and recreated the ini file
  • factory reset the printer
What am I missing?
Postato : 21/04/2024 11:52 am
threedjd
(@threedjd)
Utenti
RE: WIFI will not stay connected, MK4 + FW 6.0.0
Wifi AP is 2.4Ghz with WPA2 only
Postato : 21/04/2024 12:13 pm
aare
 aare
(@aare)
Utenti
Experiencing the same issue after upgrading to FW 6.0.0. WiFi status shows "No AP".
WiFi AP side shows no attempt to connect from the ESP.
Postato : 21/04/2024 7:23 pm
aare
 aare
(@aare)
Utenti
It seems that there is a known issue with WPA3 and the latest 6.0.0 firmware.
 [BFW-5393] [BUG] 6.0.0 - Wifi doesn't work in WPA3/WPA2 Transition mode #3864
https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/3864
After turning off WPA3 authentication in the AP configuration for the printer network it seems that the printer is able to re-establish the WiFi connection.
Postato : 21/04/2024 7:48 pm
FriedmanWD
(@friedmanwd)
Utenti
Wired Network problems after upgrading to 6.0.0 - transfers of large files fail, connection reset.... WiFi module installed but never set up or used. Prusa Mk 3.5.
Questo post è stato modificato 2 years fa da FriedmanWD
Postato : 24/04/2024 5:57 pm
T. J.
(@t-j)
Same issue here since the update to FW 6.0.0 RC1.
Using a Fritz!Box 7590.
-> After changing the WPA method from "WPA2 (CCMP)" to "WPA + WPA2" is seems to work now.
Postato : 08/05/2024 7:34 am
