Why does my printer print slower then the sliced speed?
ofer feldman
(@ofer-feldman)
Miembro
I slice some models at around 300 mm/s, and the actual speed in the slicer showed that, the time was suppose to take 14 minutes, it took about 45 minutes, why?
Respondido : 15/09/2024 5:26 pm
Venice3D
(@venice3d)
RE: Why does my printer print slower then the sliced speed?
The speed you specify is only one of the factors. There's also a maximum volumetric rate (how much plastic can go through the extruder per second) and a minimum layer time to allow for cooling, plus maybe others that don't come to mind right now.
Respondido : 16/09/2024 2:53 am
ofer feldman
(@ofer-feldman)
Miembro
these are the speeds the slicer says, and it took 2x time
Respondido : 16/09/2024 5:24 pm
Venice3D
(@venice3d)
It might also be limited by the acceleration of the printer. It looks like the model has a lot of changes in direction and so there might just not be enough time for it to get up to the target speed on any segment. I don't know whether "actual speed" takes acceleration into account, or whether this happens later, in the firmware.
Respondido : 16/09/2024 9:56 pm
This ought to be sticky:
The speed you set is the maximum permitted; high values will only be reached on long, straight, extrusions.  You will see no difference in small prints.
Respondido : 16/09/2024 11:45 pm
ofer feldman
(@ofer-feldman)
Miembro
it does
Respondido : 17/09/2024 1:31 pm
