Solid layers...........
Dave M (NZ)
(@dave-m-nz)
Hi All,   Is there any way to make 4 or 5 layers solid print at many point in the print process ?     This would be handy on thin layer width parts.
( A bit late but merry xmas, happy printing)
Veröffentlicht : 26/12/2023 3:30 am
Use modifiers.  Right click on obect, add modifier, adjust size and position, right cluck on modifier, select infill and edit.
Veröffentlicht : 27/12/2023 10:48 am
Alternatively you may want to use the Expert level setting under Print Settings>Infill>Advanced>Solid Infill every: which allows you to define a solid infill layer every X layers.
Modifiers are more targeted of course, but it is a setting you can add to individual objects using the Add Settings>Infill function
Veröffentlicht : 27/12/2023 11:54 am
You're right @neophyl, I'd forgotten that setting.  Either way will work.
Cheerio.
Veröffentlicht : 27/12/2023 1:59 pm
Dave M (NZ)
(@dave-m-nz)
RE: Solid layers...........
Thanks guys, I will give it a go..........
Veröffentlicht : 27/12/2023 9:51 pm
