Solid layers...........
Hi All, Is there any way to make 4 or 5 layers solid print at many point in the print process ? This would be handy on thin layer width parts.
( A bit late but merry xmas, happy printing)
Use modifiers. Right click on obect, add modifier, adjust size and position, right cluck on modifier, select infill and edit.
Alternatively you may want to use the Expert level setting under Print Settings>Infill>Advanced>Solid Infill every: which allows you to define a solid infill layer every X layers.
Modifiers are more targeted of course, but it is a setting you can add to individual objects using the Add Settings>Infill function
You're right @neophyl, I'd forgotten that setting. Either way will work.
Cheerio.
RE: Solid layers...........
Thanks guys, I will give it a go..........
