Really Strange Error Code
Fiepixy08
(@fiepixy08)
MK4, upgraded from an MKS3+, recently switched to a .25mm nozzle for DnD Miniatures Printing, Re-calibrated entire printer for new nozzle, set Slicer program to provide non-binary Gcodes. All other settings are standard. Slicer is fully up to date and running basic profiles with only cosmetic changes (Supports, infill percentage, ect) and no major changes to temp settings or anything of that sort.
The Preview screen for the print also cuts off the bottom 3rd of the visual
It keeps giving me a strange error code: +@?9w9.)?s`U93?62?0?.3!}7y?G1
As well as before the printing begins it will start extruding filament from the nozzle for the test line before it's even reached the bed.
My initial thought is perhaps a corrupted Slice? Though I've tried re-slicing it to the same results.
Any Thoughts or ideas?
Opublikowany : 02/06/2024 5:21 pm
Files > Save Project as
Cheeio,
Opublikowany : 03/06/2024 6:11 am
ironfan72
(@ironfan72)
RE: Really Strange Error Code
I believe this is normal behaviour. Both of my MK4s do this, I realize it's not what the Mk3S did but seems to be a change for the Mk4.
Posted by: @rebecca-shryock
Opublikowany : 03/06/2024 2:42 pm
Fiepixy08
(@fiepixy08)
I'm thinking it was a corrupted slice, I tried to pull it up in the Prusa GCode Viewer and got the following message:
Configuration block opening tag "; prusaslicer_config = begin" not found when reading E:\<*Folder Name Here>\<*File Name Here> 44.03g 3h40m.gcode
*Folder and File name changed for copyright reasons.
Opublikowany : 03/06/2024 11:21 pm
